MorganM Posted August 31, 2004 Share Posted August 31, 2004 On say a GL10 turbo with four wheel disc brakes. Is there a porportioning valve in the rear? I didn't think OEM 4 wheel disc brakes used one in the rear but porportioned everything up front. I'd look myself but the nearest one is a 2 hour drive accross the state border Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 31, 2004 Share Posted August 31, 2004 Where do I look exactly? I have one on jacks in my driveway right now that I can check for you.... 88 GL-10 sedan... If you have an FSM it should have a diagram of the complete brake system - that's where I looked to see if there was any such thing on the EA81's..... GD Link to comment Share on other sites More sharing options...
edrach Posted September 1, 2004 Share Posted September 1, 2004 Where do I look exactly? I have one on jacks in my driveway right now that I can check for you.... 88 GL-10 sedan... If you have an FSM it should have a diagram of the complete brake system - that's where I looked to see if there was any such thing on the EA81's..... GD I don't know if you need to care. I've done about 8 of the conversions on EA81 vintage cars and never noticed that I might need to change the proportioning valve. All of them have worked just fine along with working better than the original drum rears. Link to comment Share on other sites More sharing options...
mcbrat Posted September 1, 2004 Share Posted September 1, 2004 yeah. Jerry (bratsrus1) did some testing of the actuating pressure, and it was the same for the rear ea81 drums as the rear disks, so nothing else had to change.... Link to comment Share on other sites More sharing options...
