DIY 2" exhaust tips?
OK well on my way w/ my project wagon. Lift is done but now I wanna put in a 2" pipe from the cat back, might gut the cat after I pass emissions.
Anyone got an idea of what-all I need for angle peices etc from prev goes?
I do have access to a wire fed welder and a cut off saw for good angles- will a tail pipe expander open up the tubing enough to swag it together?
Whelp, don't everybody jump at once.
So far, so good.
I cut the old flange off, after a little grinding to taper the fuji bead I was able to get it sitting snug in the 2" tube and welded it in.
Looks like at about 62" it needs to go into a 60* then maybe another pc (on stock at this point seems to commonly be a 90*) to the muffler. I grabbed a turbo free-flow at action for $30.
I'll keep yall posted.
