max cruising speed
I've got an 87 turbo wagon with a pretty tight motor. I run mobil one and have never had any cooling problems. i was wondering what's the max rpm's to pull SAFELY for extended periods of time. When i cruise about 60 mph, my vacuum is about 9 in. , but when i cruise at 70 it jumps to about 11 in. 70 is also about 3500. Does anyone else get about the same vacuum readings and how fast does everyone else cruise.
Sounds like you have an Automatic. Typical rpms for one.
I think 70mph is ok for cruising and it keeps the motor in its powerband. If you want to change the rpm's, change your wheels to 14in Pugs, it helps alot without drastic drivetrain changes/swaps.
