dustyrider Posted September 5, 2004 Share Posted September 5, 2004 Question is as follows i have a 86 hatch and i want to take the control arm off a 85 gl wagon. are they the same??? i only ask cause they appear to be a differnt size. small differences in how it hooks to the body too? let me know soon so i can work on it today i got some help if i can get a reply!!! any hints on how to make this and easier job than it appears would be helpful:brow: thanks :cool: Link to comment Share on other sites More sharing options...
baccaruda Posted September 5, 2004 Share Posted September 5, 2004 no, the ball joint holes are smaller on your stock control arm, and they're aligned a little differently. why does your hatch need its control arm switched? Link to comment Share on other sites More sharing options...
dustyrider Posted September 5, 2004 Author Share Posted September 5, 2004 no, the ball joint holes are smaller on your stock control arm, and they're aligned a little differently. why does your hatch need its control arm switched? it got bent and i want to replace it before anything happens. mainly cause i thought i had one sitting in the yard. so i guess it has to come from another hatch than????? Link to comment Share on other sites More sharing options...
dave valiant Posted September 5, 2004 Share Posted September 5, 2004 You should be able to use one off of any EA81 car. Link to comment Share on other sites More sharing options...
dustyrider Posted September 6, 2004 Author Share Posted September 6, 2004 You should be able to use one off of any EA81 car. this is what im told. but the measurement is too long i better check to see if it is in fact an ea81 perhaps there is something i dont know about this subaru. thanks Link to comment Share on other sites More sharing options...
ezapar Posted September 6, 2004 Share Posted September 6, 2004 The arm you need is indeed one from any ea81. FWD or 4WD. Link to comment Share on other sites More sharing options...
dustyrider Posted September 6, 2004 Author Share Posted September 6, 2004 The arm you need is indeed one from any ea81. FWD or 4WD. ahhh i figured it out the 85 gl wagon in the back is a ea82 so no swapping there. there is a 82 wagon with a parts car in the paper im going to call and see if its a ea 81. Link to comment Share on other sites More sharing options...
edrach Posted September 6, 2004 Share Posted September 6, 2004 ahhh i figured it out the 85 gl wagon in the back is a ea82 so no swapping there. there is a 82 wagon with a parts car in the paper im going to call and see if its a ea 81. An '82 wagon should certainly be an EA81 model. Link to comment Share on other sites More sharing options...
ezapar Posted September 6, 2004 Share Posted September 6, 2004 ea81 is the name for the 1800 engine that came in that body style. ea71 is the 1600, it may have that engine instead if it's a DL. A 1982 wagon will have the part you are looking for, never mind if it has an ea81 engine in it or not. Grab the radius arm too. The one you have has been banana'd and bent back straight. Link to comment Share on other sites More sharing options...
dustyrider Posted September 6, 2004 Author Share Posted September 6, 2004 ea81 is the name for the 1800 engine that came in that body style. ea71 is the 1600, it may have that engine instead if it's a DL. A 1982 wagon will have the part you are looking for, never mind if it has an ea81 engine in it or not. Grab the radius arm too. The one you have has been banana'd and bent back straight. got ya. if i can get this car for parts i will have everything. i need expect drive train stuff. it has cool 13 alloys too. i am wondering how easy it is to take off that lower knuckle under the hub. will hub just stay put while i remove the control arm or do i need to do something with the suspension...... :cool: Link to comment Share on other sites More sharing options...
