23 spline 5 lug swap
XSNRG
I am pretty sure (although not 100%) that the AXLE SHAFT itself is the same, just the joints are different, if that is the case then it would be a simple matter to buy a inner boot kit and put the 23 spline inner joints on the XT6 axles......
The axle shafts are not the same, but the inner joint will interchange.
