XSNRG Posted September 9, 2004 Share Posted September 9, 2004 Is this possible? I know generally a 25 spline trans is used with this conversion but I'm wondering if EA82 axles can be used or if the DOJ on the XT-6 axles can be swaped with the 23 spline. Link to comment Share on other sites More sharing options...
Subarutex Posted September 9, 2004 Share Posted September 9, 2004 Perhaps it would be easier to swap out the stub axles on the trans. If they work the same way as the rear diff... Also... i'm pretty sure cvaxles.com has made some of these for someone... oh! It was subarustyles. Link to comment Share on other sites More sharing options...
edrach Posted September 9, 2004 Share Posted September 9, 2004 www.cvaxles.com will make you a set of custom axles for your car with either the 23 or 25 tooth splines. Link to comment Share on other sites More sharing options...
Hondasucks Posted September 9, 2004 Share Posted September 9, 2004 I am pretty sure (although not 100%) that the AXLE SHAFT itself is the same, just the joints are different, if that is the case then it would be a simple matter to buy a inner boot kit and put the 23 spline inner joints on the XT6 axles...... Link to comment Share on other sites More sharing options...
Dr. RX Posted September 9, 2004 Share Posted September 9, 2004 I am pretty sure (although not 100%) that the AXLE SHAFT itself is the same, just the joints are different, if that is the case then it would be a simple matter to buy a inner boot kit and put the 23 spline inner joints on the XT6 axles......The axle shafts are not the same, but the inner joint will interchange. Link to comment Share on other sites More sharing options...
XSNRG Posted September 9, 2004 Author Share Posted September 9, 2004 OK, I'll try to swap the DOJ and see if it fits, sounds good! Link to comment Share on other sites More sharing options...
subaru_styles Posted September 9, 2004 Share Posted September 9, 2004 with some advise from corky i had cvaxles build me a set of xt6 ones with 23 inner DOJ #95lac Link to comment Share on other sites More sharing options...
PoorManzImpreza Posted September 10, 2004 Share Posted September 10, 2004 lol when we did the carbed ej18 swap we just slid the inner race of the ea DOJ into the 25 spline cup of the legacy DOJ..worked fine..ghetto, but fine ;-) Link to comment Share on other sites More sharing options...
XSNRG Posted September 10, 2004 Author Share Posted September 10, 2004 Cool... Link to comment Share on other sites More sharing options...
