D.A.L Posted September 9, 2004 Share Posted September 9, 2004 Hey all, I was just driving my car and had a realy bad smell enter the compartment. When I opened the hood I traced the smell to the AC compressor, I touched the face of the clutch/pulley and it was extremely hot. Has anyone experienced this before? And if the compressor is toast can I simply bypass it with a different belt or just remove it as the fix may be worth more than the car? First time posting, hope you can help! Don Link to comment Share on other sites More sharing options...
Legacy777 Posted September 9, 2004 Share Posted September 9, 2004 Yup....your compressor seized. Mine did this a few months ago. You can take off the rear belt....or just not turn on the a/c and you should be fine. The best solution would be to disconnect the electrical connector from the compressor. that way the clutch won't engage if you accidently hit the a/c or defrost buttons. Link to comment Share on other sites More sharing options...
D.A.L Posted September 9, 2004 Author Share Posted September 9, 2004 Thanks for the info! I'm just going to cut the belt as up north here we only use the AC a couple of weeks of the year. By the way I was checking to see if the belt runs anything else (93 Legacy, auto, 2 wh drive) but it seems not to so what runs the water pump? Thanks, Don Link to comment Share on other sites More sharing options...
gbrand Posted September 9, 2004 Share Posted September 9, 2004 The water pump is driven by the timing belt. My A/C compressor locked up this spring, in Texas gotta have it and lucked out with a JY replacement , new drier, flush and fill of system. good luck Thanks for the info! I'm just going to cut the belt as up north here we only use the AC a couple of weeks of the year. By the way I was checking to see if the belt runs anything else (93 Legacy, auto, 2 wh drive) but it seems not to so what runs the water pump? Thanks, Don Link to comment Share on other sites More sharing options...
