soobme Posted September 9, 2004 Share Posted September 9, 2004 OK, I'm getting ready to strip out EVERY last wire from my EA81 wagon and make a new harness for it. But I need to know where the 2 wires from the dizy go to My harness is soooooo bad that I can't even trace them out Also, is all the ignition housed in the dizy, or is there an ignition box hiding some where that I haven't found? This is on an '82 DL wagon. Link to comment Share on other sites More sharing options...
mcbrat Posted September 9, 2004 Share Posted September 9, 2004 the two dizzy wires should go to either side of the coil. not part of the harness at all. the 82 dizzy should have all the IGN stuff inside. nothing external. Link to comment Share on other sites More sharing options...
archemitis Posted September 9, 2004 Share Posted September 9, 2004 and if its like mine, the red goes to the + and the yellow goes to the negative, but... it may not matter. Link to comment Share on other sites More sharing options...
soobme Posted September 9, 2004 Author Share Posted September 9, 2004 That's to eazy So it just gets it's power from the + side of the coil, and then sends the signal back to it on the - side!?!? Link to comment Share on other sites More sharing options...
archemitis Posted September 9, 2004 Share Posted September 9, 2004 well, on the negative side you will also have a tach wire coming off the coil, and there needs to be a power wire going to the +side of the coil, along with the one coming off the distributor. Link to comment Share on other sites More sharing options...
oddcomp Posted September 9, 2004 Share Posted September 9, 2004 ahem.. cough edis cough Link to comment Share on other sites More sharing options...
