swisscheese Posted September 9, 2004 Share Posted September 9, 2004 If you could get a USDM EJ25 SOHC for the same price as a JDM EJ20 DOHC single turbo, which would you choose and why? This would go in a 88 wagon adapted to a EA82 5spd Dual Range with roughly 28 inch tires for light off-roading duty. Thanks! Link to comment Share on other sites More sharing options...
baccaruda Posted September 9, 2004 Share Posted September 9, 2004 well, the 2.5 is infamous for head gasket problems due to the open deck design, but a N/A motor has better low end torque for offroad use. the 2.0 is a closed deck design so its head gaskets aren't vulnerable to defective design, but may be to how you drive with a turbo .. and if you truly mean light offroad use, then it won't matter with the turbo. if it were me and the 2.5 did NOT have the HG issue, i'd choose that for offroading, otherwise i'd choose the 2.0 turbo as i don't think it'll affect what you do too much. Link to comment Share on other sites More sharing options...
archemitis Posted September 9, 2004 Share Posted September 9, 2004 turbos rool, and the 2.0 has been pushed to the limits and holds together well. id say 2.0 turbo action! Link to comment Share on other sites More sharing options...
Snowman Posted September 9, 2004 Share Posted September 9, 2004 2.0 turbo all the way. It's still gonna have way more low end than the engine that used to be in the car, and none of the reliability/durability issues of the EJ25. Link to comment Share on other sites More sharing options...
northguy Posted September 9, 2004 Share Posted September 9, 2004 2.0 = bulletproof 2.5 = potential headgasket problems Link to comment Share on other sites More sharing options...
swisscheese Posted September 10, 2004 Author Share Posted September 10, 2004 If I am not mistaken, all EJ25's have open deck, but EJ20G came either open or closed. Do the open deck EJ20's have the same reputation for head gasket problems as the EJ25? Link to comment Share on other sites More sharing options...
WJM Posted September 10, 2004 Share Posted September 10, 2004 Rarely do the EJ25x's have headgasket issues. The EJ251 SOHC engine is a sound engine. Ive not had a problem. Ive also got an EJ25D (the DOHC version, phase one) and its clocked up 190k+ miles with no issues at all. Go with the EJ251 for off road. The EJ20G is a closed deck engine, good for 400 hp on stock internals. But its powerband is NOT good for off road...read power come son at 3k+. Power on the EJ251 is there around 2k. Link to comment Share on other sites More sharing options...
swisscheese Posted September 10, 2004 Author Share Posted September 10, 2004 Would advancing the camshaft(s) have the same effect in a turbo engine as in a normally aspirated--e.g lowering the torque curve at the expense of high-end horsepower? Thanks for all the help, I am a soob noob and before I fork over a lot of dough, I want to be sure I am going the right way. Naturally, I want it all, 400 HP, 400 foot pounds at 2000 RPM, 35 miles per gallon, 100,000 miles between servicing, and 500,000 miles until rebuild. Link to comment Share on other sites More sharing options...
JWX Posted September 10, 2004 Share Posted September 10, 2004 lol............thats funny.................ya you're not going to get that.............. funny thou.................but no Link to comment Share on other sites More sharing options...
WoodsWagon Posted September 11, 2004 Share Posted September 11, 2004 If your car has a D/R tranny, I'd go with the turbo. In first low, the engine can be in its power range and you're only going like 5 mph. What bout the new 2.5 turbo's? that would give you everthing except fuel economy. Link to comment Share on other sites More sharing options...
Mykeys Toy Posted September 11, 2004 Share Posted September 11, 2004 I thought the EJ25 went to closed deck after 99 or was that the EJ20? Mike Link to comment Share on other sites More sharing options...
WJM Posted September 11, 2004 Share Posted September 11, 2004 Mykeys Toy said: I thought the EJ25 went to closed deck after 99 or was that the EJ20? Mike EJ20G/22G is closed deck. EJ207/257 is semiclosed. All the rest are open deck. Link to comment Share on other sites More sharing options...
THAWA Posted September 11, 2004 Share Posted September 11, 2004 the ej207 is open. There are only two closed decks, 22g and 20g, and one semi, 257 also the na ej25's ARE notorious for headgasket problems Link to comment Share on other sites More sharing options...
WJM Posted September 11, 2004 Share Posted September 11, 2004 THAWA said: the ej207 is open. There are only two closed decks, 22g and 20g, and one semi, 257 205 is the "world turbo EJ20" and its the US spec WRX engine - open deck. the 207 is the version 7+ STi engine. It IS semi. Same as the 257 block...just less displacement. When they moved from the GC...they dropped the 20G for both lines - WRX/STi - and gave the STi a new block, the 207. Semi closed. Good for about 400-450 hp. The WRX got the 205, good for 350 MAX. I heard stories that it had something to do that ppl tohught i was not right that you could buy a cheap rump roast WRX and hop it up to be faster than an STi on the stock engine...so they changed that. BIG time. Now the STi is faster unless you do an engine swap in a WRX. 207 is semi. Link to comment Share on other sites More sharing options...
THAWA Posted September 11, 2004 Share Posted September 11, 2004 the "G" blocks stopped getting made sometime between 94-96 (aside from the 22b) There is only one semi closed block, 257. If you'd like to disprove me please post a picture, or a factual link. I'll gladly eat my words. Link to comment Share on other sites More sharing options...
WJM Posted September 11, 2004 Share Posted September 11, 2004 http://www.rallispec.com/product-eng_1.htm http://www.spdusa.com/new_page_4.htm Link to comment Share on other sites More sharing options...
THAWA Posted September 11, 2004 Share Posted September 11, 2004 pass the ketchup Link to comment Share on other sites More sharing options...
WJM Posted September 11, 2004 Share Posted September 11, 2004 THAWA said: pass the ketchup Everyone learns something at 3 am! I still read that spdusa page over and over from time to time... Link to comment Share on other sites More sharing options...
Mykeys Toy Posted September 11, 2004 Share Posted September 11, 2004 At least you eat those words with dignity Mike Link to comment Share on other sites More sharing options...
