ej cam sensor info?
oddcomp
oddcomp
here is what www.alldatapro.com says, for a
2003 Subaru Impreza WRX F4-1994cc 2.0L DOHC Turbo MFI
crankshaft sensor
  • The crankshaft position sensor is installed on the oil pump which is located in the front center portion of the cylinder block. The sensor generates a pulse when one of the teeth on the perimeter of the crankshaft sprocket (rotating together with the crankshaft) passes in front of it. The ECM determines the crankshaft angular position by counting the number of pulses.
  • The crankshaft position sensor is a molded type which consists of a magnet, core, coil, terminals and other components as illustrated.
  • As the crankshaft rotates, each tooth aligns with the crankshaft position sensor. At that time, the magnetic flux in the sensor's coil changes since the air gap between the sensor pickup and the sprocket changes. This change in magnetic flux induces a voltage pulse in the sensor and the pulse is transmitted to the ECM.
camshaft sensor
  • The camshaft position sensor is located on the left-hand camshaft support. This sensor detects the combustion cylinder at any given moment.
  • The sensor generates a pulse when one of the bosses on the back of the left-hand camshaft drive sprocket passes in front of the sensor. The ECM determines the camshaft angular position by counting the number of pulses. Internal construction and the basic operating principle of the camshaft position sensor are similar to those of the crankshaft position sensor. Two bosses are provided on the sprocket as shown.
sorry i dont know how many teeth.
-=suberdave=-
thanx i will pass it along to the guy doing all teh code mods on the megasquirt and edis code i think thats enough info to at least know if it can be done wishi had a ej here i could look at
thanx again
from what i know tho.. handleing that info shouldn't be a problem
for the ms box
