Ratty2Austin Posted September 13, 2004 Share Posted September 13, 2004 I just got done making a custom intake snorkel for my EJ22, but the one piece I still need is a end-to-end rubber clamp deal that will attach my intake to the manifold... (the 2.25" opening? I would assume that some of the guys who do cold air intakes would know where to get one? thanks!! (the duct tape is not very heat resistant!! and i need the real deal soon! ) Link to comment Share on other sites More sharing options...
Adam N.D.J. Posted September 13, 2004 Share Posted September 13, 2004 Hit up home depot, they have a good number of different sizes of rubber connectors for attaching different sized pipes and stuff. Jes check out the plumbing area, typically around the ABS. Link to comment Share on other sites More sharing options...
coloradosubarules Posted September 14, 2004 Share Posted September 14, 2004 You puled this off without getting the Check Engine light. Nice! I keep hearing horor stories of people doing this mod with no luck. Hope it works well for you. Link to comment Share on other sites More sharing options...
Ratty2Austin Posted September 14, 2004 Author Share Posted September 14, 2004 well, i probably have the "check engine light" on , but i cant tell, cause I have no light! (the wires are there somewhere ) tex helped me out.. we discovered that the wrx intercooler connector is exactly what i needed! the ones at home depot and lowes are all 2 or 3" only! (intake is about 2.4" or something like that....) thanks! Link to comment Share on other sites More sharing options...
DerFahrer Posted September 14, 2004 Share Posted September 14, 2004 You had to maintain the MAF sensor attached to the stock airbox in your setup. If you removed it, you'd have far more than just a CEL. The car would run terribly, sputter, and most likely die, because it judges the A/F ratio mostly on readings from the MAF... Link to comment Share on other sites More sharing options...
