86subaru Posted September 14, 2004 Share Posted September 14, 2004 i have a chance to get a xt6 , will a single range tranny that is already in an xt fit and work in an xt6 ? are the xt6 ' s motors the same as regular ea82 motor ? like timming belts, water pumps, etc... Quote Link to comment Share on other sites More sharing options...
DerFahrer Posted September 14, 2004 Share Posted September 14, 2004 Definitely check out xt6.net for more info... Any EA-series tranny will bolt up, however, keep in mind the ratios in the 4cyl cars were designed to get a low-power engine moving as quickly as possible (read: VERY short ratios). You will run out of gears with a flat-6 so fast it would be scary... The accessories of the motor are pretty much the same, yes. Oil pumps are pretty much the same, timing belts, water pumps. The alternators, though are different, and the power steering is a night-and-day difference, as 6's have the electrically-driven Cybrid steering system. Quote Link to comment Share on other sites More sharing options...
86subaru Posted September 14, 2004 Author Share Posted September 14, 2004 ok, thanks Quote Link to comment Share on other sites More sharing options...
