Mike V Posted September 17, 2004 Share Posted September 17, 2004 Hello again, Well, as I mentioned in previous thread, my '97 2.2 MT failed PA state emissioins testing because the CEL is on. I asked the inspection station (actually just your basic local garage/gas station) guy to pull the codes and when I picked up the car last night they told me the computer says I have a misfire on Cyls 2 and 4. The guy there suggested I replace the spark plugs and ignition wires, drive the car around a few days and "maybe" that the computer will clear. I do not like to "fix" things in this manner (i.e. replace a part and hope for the best). Also, I replaced the plugs and wires about a year ago. I plan to stop by my local Subaru dealer at lunch today and chat with a mechanic there who has been helpfuil in the past. Any suggestions or comments? Thanks! Mike V Link to comment Share on other sites More sharing options...
Subie Gal Posted September 17, 2004 Share Posted September 17, 2004 misfire codes are tough to diagnose. plugs, wires, ecu? coil pack? injectors? could be a handfull of things... if you dont want to try to sort it yourself, get it to a pro to help you diagnose. Jamie Link to comment Share on other sites More sharing options...
slo5oh Posted September 17, 2004 Share Posted September 17, 2004 misfire in the cyl? most probable causes: bad spark plugs (but why is another question) bad plug wires corosion on plug wire connections head gasket failure (probably not with the 2.2) bad coil bad gas I would do a simple tune up: new plugs, wires, and pick up a tube of dielectric grease to coat all the connections. Then pull your battery cables for a half hour and let her relearn everything. You will probably have to wait a week before resmogging it after clearing the codes. read your plugs when you pull them out. There's a great website for this, do a google search. White is bad, black is bad, green is real bad, tan to brown is good. *edited to add* After the tune up run a bottle of redline fuel injector cleaner in it. I usually use half the bottle with a full tank every 20k or so. Link to comment Share on other sites More sharing options...
