rear defrost not working
Look down the defrost stripes on the back window. Most likely one of the stripes got corroded. They sell a kit to fix it at napa. Its like 10 bucks. If the stripes are bad in one spot, it should be darker then the rest of them.
Clean it off with rubbing alcohol and install the glue like the package says
Its like 30 F up here right now. The fires are finally out. Where at in Bristol Bay did you guide? I grew up in Naknek. If you got msn messenger add me.
whitey@myself.com
Not much for the messenger thing, not that this is much different... but I worked on the nushigak river and togiak... the lodge was located in wood tikchik state park,(tikchik narrows lodge) pretty rad summer, lots of fish! conditions were pretty sketch really low water hense no rain...
Do you hear a relay click on when you push the button?
Check the connections on the grid itself, they do like to come un-attached from the grid. Doesn't take much of a hit to pop them off, either. So be carefull when checking them.
As stated in above post, check for power at the connections on the grid. One side should be hot, other side is ground. If you have power on one side, check your ground connection.
There's afew repair kits on the market, no real preferance here of one over the other.
