gsheng Posted September 19, 2004 Share Posted September 19, 2004 hi, my 1991 non-turbo wagon works well but check light on. The trouble code is #45,atmospheric pressure sensor-faulty sensor. So, what's possible reseason for that? I appreciate for kind instruction. I also try to clear the code with battery out and fuse disconnection, neither of such ways work. What's should I do then? guoqing Link to comment Share on other sites More sharing options...
Cougar Posted September 20, 2004 Share Posted September 20, 2004 The atmospheric sensor is used by the ECU to make changes to fuel mixture as the air pressure changes. This helps when you drive over mountain passes. It sounds like you may need to just replace it. Check the wiring to it first before replacing it, and make sure things are ok there. Link to comment Share on other sites More sharing options...
gsheng Posted October 3, 2004 Author Share Posted October 3, 2004 thank you very much. Link to comment Share on other sites More sharing options...
lastchance Posted November 5, 2013 Share Posted November 5, 2013 back from the dead... where is the sensor located? is it external (from the ECM) for the ea81 as it is the ea82? Link to comment Share on other sites More sharing options...
nipper Posted November 7, 2013 Share Posted November 7, 2013 it is an external sensor. I am not sure where it is on here, been ages since I have seen one. On newer subarus it is on the passenger side strut tower, and has a hose attached to it as it does double duty, on yours I dont remember Link to comment Share on other sites More sharing options...
Gloyale Posted November 8, 2013 Share Posted November 8, 2013 It is not external on the EA82 cars. It's built into the ECU. Turbo models only had a "pressure sensor" but that's really about boost sensing. Not Atmosphere. Latter models do have MAP sensors.....but not in EA82....it's in the ECU. Link to comment Share on other sites More sharing options...
lastchance Posted November 8, 2013 Share Posted November 8, 2013 On 11/8/2013 at 5:06 PM, Gloyale said: It is not external on the EA82 cars. It's built into the ECU. Turbo models only had a "pressure sensor" but that's really about boost sensing. Not Atmosphere. Latter models do have MAP sensors.....but not in EA82....it's in the ECU. and for the ea81t? Link to comment Share on other sites More sharing options...
Gloyale Posted November 8, 2013 Share Posted November 8, 2013 On 11/8/2013 at 5:20 PM, lastchance said: and for the ea81t? They have an external sensor for "High Alltitude" and one for Boost pressure. Link to comment Share on other sites More sharing options...
Gloyale Posted November 8, 2013 Share Posted November 8, 2013 On 9/19/2004 at 2:36 AM, gsheng said: hi, my 1991 non-turbo wagon works well but check light on. The trouble code is #45,atmospheric pressure sensor-faulty sensor. Code 45 is not Atmospheric control. Code 45 for a 91 Loyale would be for "kickdown control relay" Link to comment Share on other sites More sharing options...
