demsgudeatin Posted September 20, 2004 Share Posted September 20, 2004 Hello to all. Just picked up a 92 loyale with 34K miles on it and have a question on the transmission. When driving it shifts hard and the selector will move. Is this a transmission/engine mount problem? Fluid could use a change as well. Any suggestions? I did a brief search but couldn't find an answer. Link to comment Share on other sites More sharing options...
thealleyboy Posted September 20, 2004 Share Posted September 20, 2004 I'm assuming you have the A/T in your Loyale. First thought is trans fluid. Low fluid could cause it to "jump" or "slip". I would check level and condition. I wouldn't hesistate to do an A/T fluid replacement if you can find a shop that will do it for a reasonable cost. Very likely the problem is minor. I wouldn't think an A/T with only 34K could be going out on you, but I suppose it's possible. good luck, John Link to comment Share on other sites More sharing options...
demsgudeatin Posted September 20, 2004 Author Share Posted September 20, 2004 The transmission is auto, should have mentioned that. I plan on changing the fliud. Since the selector level moves when the transmission shifts, I thought the mounts could be bad causing the jump in the lever. I can pull on the alternator and see movement of the engine/trans.. Link to comment Share on other sites More sharing options...
thealleyboy Posted September 20, 2004 Share Posted September 20, 2004 demsgudeatin said: The transmission is auto, should have mentioned that. I plan on changing the fliud. Since the selector level moves when the transmission shifts, I thought the mounts could be bad causing the jump in the lever. I can pull on the alternator and see movement of the engine/trans.. If you suspect the mounts, you can verify by crawling underneath the car. They are easily visible, and replacement is not difficult if they are indeed broken. Personally, I've never seen a broken motor mount. I can't imagine what it would take to cause to make one of those bolts snap. It may be that a nut worked itself loose - or was never reinstalled after major service. good luck, John Link to comment Share on other sites More sharing options...
