Rear diff noise
I have a thumping noise coming from the rear differential of the car as I drive slowly (coasting or stopping). Sounds like it clanks or thumps with each wheel rotation.
Here's the key...when I put the car in Four-Wheel drive, the noise dissapears. I lifted the car - an 88 GL wagon - and had a friend rock the right rear wheel back and forth and the noise seems to come from the front part of the differential.
Thanks for any help.
Bruce:
I dont know why actuating 4wd would make any difference, but I had the same symptoms in my 93 Loy.
The solution was replacing the rear wheel bearings. I wouldn't jump to that conclusion until you ruled out some other things, but you should consider that possibility.
good luck, John
