EA82 Fuel Injection
I am a new member and I have a few questions;
I have just bought a 1988 EA82 with SPFI and I like to run the engine on a airboat. Does anyone have a wiring diagram.....how to setup not running it in a car....Or would it be easier to fit it and run it with a carb... and what carb is recommended.....
Thanks
Peter
id stick with the efi, for obvious reasons. i have no diagram to complete the swap, but the spfi is pretty contained, to the motor, and the wires going to the computer. you should be able to pull the harness out, and unplug if from the fusebox, give the computer, power, wire in a couple relays for the fuel pump, and ignition power, and blammo! efi.
wel you could ditch all the subaru fuel injection controlls ditch the maf sensor
keep the throttle body or go to a bit bigger one
and drop a megasquirt programmable injection controller on it
possibly far easyer than trying to make the car ecu run correctly on a air boat.. plus the megasquirt could be water proofed
btw i run one and a tiny bit more..hehehe
so.. why not a ea82turbo motor airboat?
just wondering
