Kostamojen Posted September 26, 2004 Share Posted September 26, 2004 You know, those little black plastic things that hold down the engine bay wiring in certain spots by poping into holes in the chasis... Little black strap things. I cant find them anywhere, anyone know where to find them? Link to comment Share on other sites More sharing options...
subiemech85 Posted September 26, 2004 Share Posted September 26, 2004 the junk yard also good source for fuses and fusible links post 1,111!! Link to comment Share on other sites More sharing options...
baccaruda Posted September 26, 2004 Share Posted September 26, 2004 if you can't find them at the JY, you can get them aftermarket maybe at the auto parts wiring dept or you can get tthe plastic threaded plugs (like for license plates and screw some eyehooks into them an use zip ties. Link to comment Share on other sites More sharing options...
Kostamojen Posted September 26, 2004 Author Share Posted September 26, 2004 I found some zip ties with screw holes, and some plastic thingies that probably wont work to hold them down, but it will have to do... Junkyard ones wouldnt work, because as soon as you remove these things they break. Link to comment Share on other sites More sharing options...
