howards11 Posted September 26, 2004 Share Posted September 26, 2004 Has anyone heard of using Bon Ami cleanser on car windows to remove the junk that's on them ? I saw this on another board and before I attempt this I was wondering if anyone else had heard of this use. Thanks in advance for your comments. ~Howard Link to comment Share on other sites More sharing options...
Mark-O-Back Posted September 26, 2004 Share Posted September 26, 2004 Read the label. Bon Ami says not to use it on glass. Try Bar Keepers Friend. ~ Mark-O ~ Link to comment Share on other sites More sharing options...
subiemech85 Posted September 26, 2004 Share Posted September 26, 2004 Use Bon-ami For Glass And Paint, Cleans Good Read Instructions I've Done It With Good Results Link to comment Share on other sites More sharing options...
Guest lothar34 Posted September 26, 2004 Share Posted September 26, 2004 If you use that or any other degreaser on windows, it's usually a good idea to go back over them with glass cleaner to get rid of the streaks. Make sure you clean your wipers too. Link to comment Share on other sites More sharing options...
theDirtyRue Posted September 26, 2004 Share Posted September 26, 2004 Works great. I was skeptical too. I didn't want to scratch the glass but I REALLY wanted the watermarks gone. I tested it out first ( i recomend you do to) on a back window. Once you get them all clean, I also recomend that you use the Mr. Clean autodry system. It keeps all the water stains off. Good luck, Link to comment Share on other sites More sharing options...
howards11 Posted September 26, 2004 Author Share Posted September 26, 2004 Read the label. Bon Ami says not to use it on glass. Try Bar Keepers Friend. ~ Mark-O ~ Bar Keepers Friend is very harsh ! ~Howard Link to comment Share on other sites More sharing options...
SevenSisters Posted September 26, 2004 Share Posted September 26, 2004 I've used Bon Ami on my windshield numerous times without noticing a problem, but Mark-O is right. I just read the label and it says not to use on windows or mirrors. I'll try to find something approved for glass in the future. By the way, the label also says "chicks do not scratch for food for two or three days after hatching". I learned two new things today. Link to comment Share on other sites More sharing options...
Tiny Clark Posted September 27, 2004 Share Posted September 27, 2004 Try a scotchbrite sponge/pad to clean the glass. Link to comment Share on other sites More sharing options...
NOMAD327 Posted September 27, 2004 Share Posted September 27, 2004 scotchbrite pads are great for a lot of things and come in many grits, the tough ones will probably take chrome off metal. I think the worst ones are red, and then lesser ones are grey then green then white, not sure!, I like them and as said, would definately try one first and see how it worked. Link to comment Share on other sites More sharing options...
howards11 Posted September 27, 2004 Author Share Posted September 27, 2004 I think I am going to try a Dobie Pad and a small amount of cleaner to gret rid of the gunk that has built up on the windows. The Dobie pad won't scratch the glass. Then I'll finish it with some good window cleaner like Invisible Glass. ~Howard Link to comment Share on other sites More sharing options...
howards11 Posted October 3, 2004 Author Share Posted October 3, 2004 I found something better to get the gunk off the windows before you clean them. I used a Dobie Pad on the window with some 91% rubbing alcohol. You should see all the junk come off ! I then cleaned the windows with Invisible Glass. The windows are nice and clean now ! Invisible ~Howard Link to comment Share on other sites More sharing options...
