Bob Johansen Posted September 28, 2004 Share Posted September 28, 2004 New strut to be installed soon. How can I cheaply get an x-tra couple of inches of lift ? Link to comment Share on other sites More sharing options...
bushbasher Posted September 28, 2004 Share Posted September 28, 2004 find adjustable struts for the front, and fit honda accord rear springs in the rear coilovers, that can give you something. Do a search for accord springs. The adjustable front struts are found on early ea82 wagons ('85-86) I think. Other option is to make spacers for the strut tops/coilover mounts. Either way with a suspension lift you will be significantly decreasing the life of your axles. You can do it just be prepared to be replacing cv axles regularly. Link to comment Share on other sites More sharing options...
subarubrat Posted September 29, 2004 Share Posted September 29, 2004 Which will be far more expensive and less functional in all respects than just buying the commercially available lift kit. To do a suspension lift right costs allot in money and time and involves major fabrication, upgrade to strut inserts, changed geometry etc. Even then you still pay the price in axle life. Link to comment Share on other sites More sharing options...
Numbchux Posted September 29, 2004 Share Posted September 29, 2004 the accord springs you're looking for are the FRONT ones from an '86-'89 accord, to go on the BACK of your EA82 car. And the adjustable fronts as stated earlier. If that's not enough, just cough up the cash for a BYB 3" kit, you'll be much better off in the long run. Link to comment Share on other sites More sharing options...
calebz Posted September 29, 2004 Share Posted September 29, 2004 The adjustable fronts aren't going to do you any good on a 4wd loyale wagon It has the longest available suspension of any of the EA82s..(87-94 4wd wagons).. The 85-86 adjustables, when cranked all the way up are about the same length as later model non adjustables. I have verified this by measuring the two side by side, out of the car. Side note. The struts I have in my car are from a 90 loyale 4wd wagon. The rear (non adjustable) are actually a tad longer than the adjustables (on their highest setting)I had intended to put in there. Link to comment Share on other sites More sharing options...
MorganM Posted September 29, 2004 Share Posted September 29, 2004 I know everyone wants a suspension lift but you really don't need one on these cars. A body lift is plenty of lift for a Loyale to put in bigger tires and therefore gain better ground clearance. I continue to be impressed with what my Subaru can do with just a BYB 3" body lift, 29" tires and a whole lot of RPMs. Link to comment Share on other sites More sharing options...
Subafreak Posted September 30, 2004 Share Posted September 30, 2004 Buy the Monster Loyal in the for sale forum:) Link to comment Share on other sites More sharing options...
