SubeeTed Posted September 28, 2004 Share Posted September 28, 2004 Hi ALL! OK.....I guess I'm STUPID! SOooooooooo just how do you close this Moon/Sun Roof on my 1997 Leagcy GT, Wgn? Just what does a "Positive" closing look like from inside? When the back of it is tilted up? Just what does it look like outside? Neatly sitting agaist the gasket in back, how about in front? When I first got the car....I heard any air whistle, so I moved the roof, whistle went away! Today it's really raining, Hurricane remenace. I parked the car tilted forward and to the drivers side,....SOAKED the seat! I looked at the manual, only tells you how to close, NOT what it looks like inside when it's really closed!! HELP! Soaked, Stupid, SubeeTEd!!!!! Link to comment Share on other sites More sharing options...
sunflow99 Posted September 29, 2004 Share Posted September 29, 2004 I get the same problem with my 95 legacy, sometimes it's wet, sometimes not. I know when it's closed, the back does go up. What I do sometimes is run it closed, then just crack the back open and closed with the tilt up/down switch. That's usually enough to keep it tight. Good luck! Link to comment Share on other sites More sharing options...
