the goat Posted September 29, 2004 Share Posted September 29, 2004 hey guys, i am going to look at a subaru gl-10 that has been parked for over a year. it ran when the guy parked it but now it won't start. any thoughts on what it might need to get it started? thanks. Link to comment Share on other sites More sharing options...
roxtar Posted September 29, 2004 Share Posted September 29, 2004 will it turn over and just not catch or is it not even turning over? no turn over could just simply be a dead battery... they die when parked too long. could also be ignition switch or starter no catch gets more complicated to diagnose. the engine needs 3 things to start. 1.) spark 2.) fuel/air 3.) compression no spark could be bad plugs/wires, bad cap/rotor, bad coil, disconnected wires to ignition components fuel related could be bad pump, clogged filter, clogged lines, leaking lines, or just a tank full of stale gas compression can be lost through shot piston rings, blown head gasket, cracked head/block and any number of other things hope all this helps Link to comment Share on other sites More sharing options...
Numbchux Posted September 29, 2004 Share Posted September 29, 2004 may want to drain/flush the gas tank, get some fresh gas in there Link to comment Share on other sites More sharing options...
75skunkaroo Posted September 29, 2004 Share Posted September 29, 2004 i just bought a '79 wagon that was parked for 7 years, put in a new battery, and poured some gas down the carb, took about 3-5 minutes of off and on cranking, but it fired right up -mike Link to comment Share on other sites More sharing options...
calebz Posted September 29, 2004 Share Posted September 29, 2004 any thoughts on what it might need to get it started? thanks. It needs: Fuel Air Spark Compression. Figure out how to supply those things and you will be good to go. Link to comment Share on other sites More sharing options...
the goat Posted September 29, 2004 Author Share Posted September 29, 2004 thanks for the answers. the owner said he parked it because it had suspension problems that he didn't want to take care of. what kind of suspension would a 87 gl-10 have? different than the basics? Link to comment Share on other sites More sharing options...
calebz Posted September 29, 2004 Share Posted September 29, 2004 Its very possible that it had air suspension.. My 87 GL-10 did.. that stuff is way more trouble than its worth.. and terribly expensive to fix.. however, it can be converted to regular strut/shock setup for pretty cheap, depending on availability iof parts in your area. Link to comment Share on other sites More sharing options...
canajun2eh Posted September 29, 2004 Share Posted September 29, 2004 The "no start" condition is probably due to a broken timing belt. Link to comment Share on other sites More sharing options...
MilesFox Posted September 30, 2004 Share Posted September 30, 2004 if the car ran when he parked it, the fuel pump may have seized. check to see if you can hear or feel the fuel pum come on. it will come on for 2 seconds when you turn the key ON. you can also pop the panel off from under the steering column and plug in the green connectors, that will cycle the fuel pump on and off. also you can pull a fuel line from the filter and see if fuel comes out, it should spew out at high pressure, out past from under the hood! if you dont hear the fuel pump, plug in the green testers and turn the key on. use a voltmeter or test light and probe the red wire on the fuel pump's clip and ground to the body and see if it lights up. if it does, then you know there is power. then ground the lead to the black wire, + still on the red wire. if you have light or 12v then the ground is good. if not you can splice a wire and cround it to the body. i like to run the wire thru the brake line grommet and ground to the seat belt bolt. if there is no power at all, check the relay, its under the dash and mounted to a clup on the left of the steering column above the ecu. if you want to try a quick fix to get it started run a wire from the battery to the red wire on the fuel pump and see if it comes on. if it comes on that way, you can rig the wire to the + coul terminal so the pump goes off and on with the key, until you can find the real problem Link to comment Share on other sites More sharing options...
