Mykeys Toy Posted September 29, 2004 Share Posted September 29, 2004 Is it easier to crank the susp. back down with the car raised or on the ground? My 86 hatch is eating axles and tires and she is getting expensive.I also would like to know what size wrench is needed for the job, yea I am being lazy but my son also played with my tools and has them scattered throughout the garage (Grrr). I have gotta get it done. Mike Quote Link to comment Share on other sites More sharing options...
calebz Posted September 30, 2004 Share Posted September 30, 2004 IIRC, its a 21mm.. but then again My experience with EA82s might be clouding my memories. Quote Link to comment Share on other sites More sharing options...
LUVMYBRAT Posted September 30, 2004 Share Posted September 30, 2004 weight off suspension in my experience, your letting the front spring expand out again, so load off means no binding, I believe 21mm is rightfor front I forget about back. Quote Link to comment Share on other sites More sharing options...
dustyrider Posted September 30, 2004 Share Posted September 30, 2004 21mm for the front end and i didnt un weight the car i just turned em in the parking lot. the back end is gonna take a extension off your socket but its not a 21mm should be smaller... Quote Link to comment Share on other sites More sharing options...
Mykeys Toy Posted September 30, 2004 Author Share Posted September 30, 2004 Thank you for the replies.. The back seems to be stock, so it will be the front that will get the attitude adjustment. Mike Quote Link to comment Share on other sites More sharing options...
Sweet82 Posted September 30, 2004 Share Posted September 30, 2004 I put penetrating oil on my struts a day before I tried to adjusts them down. I also moved the wrench back and forth many times before I re-set my wrench again. You don't want to mess up those threads! Good luck, Glenn 82 SubaruHummer 01 Forester Quote Link to comment Share on other sites More sharing options...
Mykeys Toy Posted October 5, 2004 Author Share Posted October 5, 2004 Well have it adjusted .. but ran out of time to get it right so i have one side slightly lower than the other but looks like the wheels are straight up and down or closer... I will have to finish the project this weekend. Thanks for the help. mike Quote Link to comment Share on other sites More sharing options...
