JWX Posted September 30, 2004 Share Posted September 30, 2004 on my 88 RX it only works on high(or fan speed 4) and even then its kind of weak. Is this the fan resistor thing? Link to comment Share on other sites More sharing options...
86subaru Posted September 30, 2004 Share Posted September 30, 2004 that would be my guess , same thing on my turbo a/t full time 4wd wagon Link to comment Share on other sites More sharing options...
JWX Posted September 30, 2004 Author Share Posted September 30, 2004 does anybody have the link for the fix then? I can't seem to find it by searching. Link to comment Share on other sites More sharing options...
Flow Posted September 30, 2004 Share Posted September 30, 2004 JWX said: does anybody have the link for the fix then? I can't seem to find it by searching.I just pull the resistor blocks at the yard and keep changing them out. If your looking for a more permanent fix: http://www.ultimatesubaru.org/forum/showthread.php?t=2614&page=2&pp=20&highlight=resistor+block Or maybe http://electronickits.com/kit/complete/motor/ck1400.htm Good luck. Link to comment Share on other sites More sharing options...
JWX Posted September 30, 2004 Author Share Posted September 30, 2004 how do you know which ones are good? Link to comment Share on other sites More sharing options...
edrach Posted September 30, 2004 Share Posted September 30, 2004 Look at them; there are three coils of resistor wire. If any one or all of them are broken the unit is no good. Be very careful handling the wires, they are very fragile after all this time and you might pull a good one and find a broken wire on it when you get home. Your best bet is to look for the newest Loyale or GL model you can fine (same unit from '81 to '93). JWX said: how do you know which ones are good? Link to comment Share on other sites More sharing options...
JWX Posted October 1, 2004 Author Share Posted October 1, 2004 cool thanks Link to comment Share on other sites More sharing options...
JWX Posted October 7, 2004 Author Share Posted October 7, 2004 where are they at? I've looked and I can't find them Link to comment Share on other sites More sharing options...
Flow Posted October 7, 2004 Share Posted October 7, 2004 JWX said: where are they at? I've looked and I can't find them There's a good pic in this link. http://www.ultimatesubaru.org/forum/showthread.php?t=10108&highlight=resistor+block Link to comment Share on other sites More sharing options...
maximumBRAT Posted October 7, 2004 Share Posted October 7, 2004 mine did the same type of thing where it only worked in one selection, only in that instance it was the temp select (knew it was heating, it just wasn't blowing) turned out to be the switch wiring problem. those slanted consoles have a lot of problems, go out quick and whatnot. however i am not sure about the knob... i think you should go for the swap out, i don't have any better pictures, but you could get one cheap, and that will likely solve your problem. if it doesn't, look into it being a wiring problem. Link to comment Share on other sites More sharing options...
