hammer008 Posted October 2, 2004 Share Posted October 2, 2004 Would someone be so kind enough to tell me where it is located? I know it is supposed to be under the steering wheel somewhere but I can not seem to find it. All I see is the fuse box left of the brakes. Someone mentioned a vertical box but can't seem to find that either. Any help is appreciated. Link to comment Share on other sites More sharing options...
jcniest5 Posted October 2, 2004 Share Posted October 2, 2004 Look just to right of the fuse box and up. It's located vertically there. But first, you have to take out the cover piece that covers the under part of the steering column that goes all the way across the entire section above where your knees would be. After you take out that cover piece, you should see the TCU box. There are two nuts holding the TCU to the chassic bolts. They use socket 10mm. Good luck! Link to comment Share on other sites More sharing options...
coloradosubarules Posted October 2, 2004 Share Posted October 2, 2004 I have the same make/model/year Subaru and if my memory serves me correctly, the TCU is gold in color while the ECU is silver. Hope this helps as well. Link to comment Share on other sites More sharing options...
hammer008 Posted October 2, 2004 Author Share Posted October 2, 2004 A BIG THANK YOU! Link to comment Share on other sites More sharing options...
Legacy777 Posted October 2, 2004 Share Posted October 2, 2004 http://www.main.experiencetherave.com:8080/subaru/images/ecuhide.jpg Link to comment Share on other sites More sharing options...
bmed Posted November 14, 2007 Share Posted November 14, 2007 Question? Can the TCU cause tranny to slip? Robby in Spokane Wa Link to comment Share on other sites More sharing options...
Legacy777 Posted November 16, 2007 Share Posted November 16, 2007 What do you mean cause it to slip? Link to comment Share on other sites More sharing options...
