rear 4x4 noise
Make sure your driveshaft is tight against the diff :)
Do lots of offroading? Something might have made its way into the diff carrier :(
When did you last change gear oil back there? Might do that just to see if anything was in there and to get new gear oil in there.
it's an 84 brat with 85 wagon clutch, driveshaft, and transcarrier bearing is good, no mounting problems
oil was full
makes similar noise when hitting bumps, running on rebound stoppers
it's definately there when driving in 4x4 and not there when driving in fwd, when driving in same path
i have seen the noise on 2 occasions.
the first when the rear suspension started to fall out of the 88 wagon after a day of baja'n(rusty) and it pitched the diff up so that it made a sharp angle on the u'joint.
the other occasion is when we made strut extensions on the back of the RX (myoss feece's anus lift) and it offset the angle again, prblem was cured by making a drop shackle for the diff so it was all nice and straight
