DaveAP Posted October 4, 2004 Share Posted October 4, 2004 Just purchased a new brat. "87 manuel, t-tops,shell. Nice shape overall. But the t-tops leak. I haven't gotten into it yet, but it looks like the gasket for the tops is not glued in. Any advice is appreciated. By the way, I really am enjoying the hi-lo 4wd. All these years I have been making a run at hills with the '78brat. Now, just like the "old bull" I can walk up there "to see the ladys", not run! "78 brat, 3" lift, weber, 14's "87 brat, 4 sp manuel, stock Link to comment Share on other sites More sharing options...
edrach Posted October 4, 2004 Share Posted October 4, 2004 The t-top design is quite interesting. The roof forms a sort of "moat" around the rubber gasket and water should collect in the moat and drains off in the drain hole at the front corner of the t-top. If the t-tops leak, it's not normally a bad gaskest as much as the drain hole is clogged allowing the water to leak past the gasket. I cleared out my leaking problem by poking a stiff wire down the hole and squirting water down it until it drained properly. I haven't had a problem with it since. Link to comment Share on other sites More sharing options...
DaveAP Posted October 6, 2004 Author Share Posted October 6, 2004 thanks, I'll have to have a look for the hole. I didn'nt notice anything like that. I just assumed it drained around the gasket and ran off via the gutter trim. Link to comment Share on other sites More sharing options...
edrach Posted October 6, 2004 Share Posted October 6, 2004 Dave, I think I have to apologize. I think I may have described the sunroof on my Legacy. In retrospect, I think I cleaned up leaking on my Brat by putting a layer of clear silicone under the rubber gaskets of the t-tops. You're correct that the t-tops drain off around the gasket and ran off via the gutter trim. ---Ed--- thanks, I'll have to have a look for the hole. I didn'nt notice anything like that. I just assumed it drained around the gasket and ran off via the gutter trim. Link to comment Share on other sites More sharing options...
