s'ko Posted October 7, 2004 Share Posted October 7, 2004 1982 EA81. I replaced the stock coil w/the yellow accel superstock on. At first it ran great. No hesistation and lots of power. Well recently I started getting some misfiring at high RPM. I figured that the vac advance wasn't working. Someone mentioned that the Electronic Control pack on the Dist can be fried by all of the power coming from the new hot coil. anyone have a problem with this? What are possible fixes. (besides swaping out the electronic control pack every time) BW Link to comment Share on other sites More sharing options...
calebz Posted October 7, 2004 Share Posted October 7, 2004 I think its more likely that the Accell itself is crapping out. I , and a number of others have dealt with that already. Mine quit this past summer.. All started with a miss at high RPMs..... Link to comment Share on other sites More sharing options...
s'ko Posted October 7, 2004 Author Share Posted October 7, 2004 I think its more likely that the Accell itself is crapping out. I , and a number of others have dealt with that already. Mine quit this past summer.. All started with a miss at high RPMs..... How long did it take for it to die? It started to have issues on Monday night. Then Tuesday I couldn't get over 15 MPH is 1st gear. Top Speed was like 45 or so in 4th w/the car bucking like mad. Then last night I tried to limp it home. Within 15 mins of limping it got really bad and I had to get someone to come tow me home. So we are talking about maybe and 1 hour of engine opp time. Is that common? BW Link to comment Share on other sites More sharing options...
MorganM Posted October 7, 2004 Share Posted October 7, 2004 I've been running an Accel yellow super stock for almost 2 years. First and only one I've bought. If it was going to fry any ingition electronics I think it would have done it by now. Link to comment Share on other sites More sharing options...
LUVMYBRAT Posted October 7, 2004 Share Posted October 7, 2004 I run one with no issues, I have found my car to be underpowered at times but no misfires. almost 1 yr now. The threads I've read have given me some insecurity to the point of carrying a stock one along just in case. Link to comment Share on other sites More sharing options...
subiemech85 Posted October 7, 2004 Share Posted October 7, 2004 put your OLD coil back in, you did save it, didn't you?? if you still have the problem, it means you have a problem had similar issue, had to change dist, just changing the control module did no good, as it was a matter of broken and worn out parts Link to comment Share on other sites More sharing options...
s'ko Posted October 7, 2004 Author Share Posted October 7, 2004 YEp saved oil coil. I am going to try that first as it's a whole easier than pulling out my dist. If you look at the other Accel thread, I e-mail the author of the quote to ask for clarification as to what is going on. Those of you who purchased an Accel made in the USA are the luck ones. The new Accels are made in Taiwan.. those cheapo Chinese, always messing things up!!!!!!!!!!! Bosco Wang ohh wait.. that's me Link to comment Share on other sites More sharing options...
calebz Posted October 7, 2004 Share Posted October 7, 2004 My accell lasted about 10 months.. From the time it started having problems to the time it died was about 2 hours drive time... When I pulled it out, I noticed the coil wire was all puffed up from oil leaking from the top of the coil, down the wire and into the dizzy cap. Link to comment Share on other sites More sharing options...
calebz Posted October 7, 2004 Share Posted October 7, 2004 I e-mail the author of the quote to ask for clarification as to what is going on. Probably not going to have a whole lot of luck with that.. he is currently without regular internet access. I talk to him a couple times a week though and would be happy to pass on any questions you may have.. I may even be able to answer them myself... Link to comment Share on other sites More sharing options...
MorganM Posted October 7, 2004 Share Posted October 7, 2004 The new Accels are made in Taiwan.. those cheapo Chinese' date=' always messing things up!!!!!!!!!!! [/quote'] Huh maybe thats why mine hasnt craped out yet? I bought this thing YEARS ago for my 472ci caddy engine. Never put it on cuz when I went to install it I found out I had an upgraded dizzy with the coil under the dizzy cap. Threw it in a box and forgot about it.... then 2 years ago I found it and was like "HEY! This will work in my Subaru!" Link to comment Share on other sites More sharing options...
s'ko Posted October 7, 2004 Author Share Posted October 7, 2004 here is the reply that I got from IgnitionMan. The Accels are now made in Taiwan, identified by the crimp at the body to top. Full crimp all the way around the top, Taiwan. If the crimp looks like it is segmented, crimp, raised then crimp, raised, it is an Andover coil, made in Indiana. Accel refuses to do anything about the issues they have, so...I now recommend these two coils, made on the Andover line the Accel used to be made on, Black, NAPA IC12 (DO NOT USE THE IC12SB COIL) Chrome, MSD 8200 Blaster II (DO NOT USE ANY OF THE RED BLASTERS 8202, 8203, 8223). Anyone want a yellow coil-shaped paperweight? Link to comment Share on other sites More sharing options...
calebz Posted October 7, 2004 Share Posted October 7, 2004 Good info .. Thanks! Link to comment Share on other sites More sharing options...
s'ko Posted October 11, 2004 Author Share Posted October 11, 2004 So I am an IDIOT!!!!!!!!!! Misfire at high RPM was due to a badly clogged air filter. Found that out after I swapped out the dist. and spent about 2 hours playing with the timing. Link to comment Share on other sites More sharing options...
WJM Posted October 11, 2004 Share Posted October 11, 2004 ive had my accell for about 2 years now....i wonder whats causing my weird missfire at high RPMS and/or high boost..... Link to comment Share on other sites More sharing options...
mcbrat Posted October 11, 2004 Share Posted October 11, 2004 I had one Super Stock coil fail on me, bought another and it was fine. in 2 other vehicles I run the Super Coil (square block looking one) and have had no issues at all.... Link to comment Share on other sites More sharing options...
