Curb Weights
Not sure that it matters to some here but I didn't see some of this in the specifications section at ultimatesubaru.org. I'm looking at a 1987 FSM and it has all this info in it. I figure since I'm not doing anything right now, that I may as well put this up so people can check it out as a reference in the future.
These are all 1987 Modelled cars (4-Door Sedan, Station Wagon and 3-door) curb weights.
4 door Sedan *All 2WD*
DL SPFI 5MT: 2195lbs
DL SPFI 3AT: 2255lbs
GL SPFI 5MT: 2260lbs
GL SPFI 3AT: 2295lbs
GL-10 SPFI 3AT: 2415lbs
GL Turbo MPFI 5MT: 2385lbs
GL-10 Turbo MPFI 5MT: 2435lbs
GL-10 Turbo MPFI 3AT: 2470lbs
Station Wagon *All 2Wd*
DL SPFI 5MT: 2330lbs
SPFI 5MT: 2300lbs *Puerto Rico Model*
DL SPFI 3AT: 2385lbs
GL SPFI 5MT: 2395lbs
GL SPFI 3AT: 2435lbs
GL-10 SPFI 3AT: 2535lbs
GL Turbo MPFI 5MT: 2530lbs
GL-10 Turbo MPFI 5MT: 2565lbs
GL-10 Turbo MPFI 3AT: 2595lbs
3-Door *2WD*
DL SPFI 5MT: 2240lbs
GL SPFI 5MT: 2320lbs
GL SPFI 3AT: 2360lbs
GL Turbo MPFI 5MT: 2445lbs
3-Door *4WD*
GL SPFI 5MT D/R: 2460lbs
GL SPFI 3AT: 2480lbs
Full Time 4WD RX Turbo MFPI 5MT D/R: 2640lbs
Understand that I could have made a typo somewhere. I'll correct it if I did. I'm using this as a reference as well as other curb weight posts.
