monstaru Posted October 12, 2004 Share Posted October 12, 2004 what type of suspension stuff would i be able to coincide with a lift for an 86 brat to be more of a rally vehicle than a rock crawler?somje of this stuff i probably already know but am not putting it together......thanks in advance:brow: Quote Link to comment Share on other sites More sharing options...
calebz Posted October 12, 2004 Share Posted October 12, 2004 A lifted vehicle is not a good place to start for a rally vehicle. Often times, unless you are someone known to them , the tech guys won't even let a lifted vehicle run an event. Just something to keep in mind. Quote Link to comment Share on other sites More sharing options...
monstaru Posted October 12, 2004 Author Share Posted October 12, 2004 i do not really want to compete .i was thinking more for my own dimented style and uses.it would not necassarily need to have anything bigger than a couple of inches in lift.i was just wondering what i could be looking for in parts from other roo's.i believe i heard that xt6 stuff would be benificial.??? Quote Link to comment Share on other sites More sharing options...
calebz Posted October 12, 2004 Share Posted October 12, 2004 Unfortunately for you, there isn't really the interchagability of suspension parts that the EA82/ER27 cars have.. you are pretty much stuck with what you have unless you design/build your own. Quote Link to comment Share on other sites More sharing options...
monstaru Posted October 12, 2004 Author Share Posted October 12, 2004 hmmmm.....well, i think i need to go to the j/y and play a little bit.thanks anyway.... Quote Link to comment Share on other sites More sharing options...
Snowman Posted October 12, 2004 Share Posted October 12, 2004 I remember a board member recently fabbed up a heim-joint setup that replaced the rubber bushings on the front suspension radius rods. That would be something to look into. Quote Link to comment Share on other sites More sharing options...
bushbasher Posted October 12, 2004 Share Posted October 12, 2004 I would just adjust the suspension all the way up and stick some 14" pugs and 26" AT's or snow tires. Maybe find an lsd for the rear, and stick a weber on for more performance. Quote Link to comment Share on other sites More sharing options...
monstaru Posted October 12, 2004 Author Share Posted October 12, 2004 i had heard of someone putting a dual shock setup on the front of their wagon or something like that....they made their own bracket,which i think i could do.i am mainly worried about the engine weight....i can do a number of things to the back.what do you guys think about that? Quote Link to comment Share on other sites More sharing options...
calebz Posted October 12, 2004 Share Posted October 12, 2004 Engine weight? in a subaru>? You have to be kidding. Hate to tell you this son, but one good 'n pissed off 97 pound weakling can pretty much pull an old soob engine by hand SubaruBrat has some custom stuff done on his suspension. Again, fabrication is the key. and if you use suspension to lift a soob/lengthen soob suspension, you will have to make adjustments for camber problems. All involve fabrication. Quote Link to comment Share on other sites More sharing options...
monstaru Posted October 12, 2004 Author Share Posted October 12, 2004 like i said,fast ,fast ,fast, on not so nice roads.that is what i am looking for.i just read something about rx springs on the front of someones brat.i just do not like to bottom out ,it is my pet peave.to strengthen i guess would be a better term, stiffen, maybe. Quote Link to comment Share on other sites More sharing options...
Matty B Posted October 12, 2004 Share Posted October 12, 2004 Why don't you bolt on ea82 lower control arms and cv shafts, then fab up some longer castor rods. Voila - castor is way better, and neg camber all for $160 (oz). It really is an agressive front end set up when dialed in correctly. TB Quote Link to comment Share on other sites More sharing options...
edrach Posted October 12, 2004 Share Posted October 12, 2004 Stiffer is not what you want in a rally car. The idea is to absorb the energy of the road, not bounce around and weaken the car's suspension from the pounding. What you want is suspension travel and the best way to get that without changing the actual geometry is weaker springs (ideally, progressive springs that get stiffer the more they get to the end of their travel) and much more effective dampening from the shocks. like i said,fast ,fast ,fast, on not so nice roads.that is what i am looking for.i just read something about rx springs on the front of someones brat.i just do not like to bottom out ,it is my pet peave.to strengthen i guess would be a better term, stiffen, maybe. Quote Link to comment Share on other sites More sharing options...
mcbrat Posted October 12, 2004 Share Posted October 12, 2004 like i said,fast ,fast ,fast, on not so nice roads.that is what i am looking for.i just read something about rx springs on the front of someones brat.i just do not like to bottom out ,it is my pet peave.to strengthen i guess would be a better term, stiffen, maybe. I have RX springs on the front of my 82 Brat. with new struts and the RX springs it lifted the front end over an inch. I have a modified lift, and even with the RX springs and susp cranked up all the way, my axles are holding up. (though you really should urethane your tranny mounts too. the axles are almost at max extension, so any side movement of the tranny will quickly shorten the life of the axles....) and yes, my Brat is stiff with the susp cranked up in front with RX springs, and a clocked torsion bar in back.... Quote Link to comment Share on other sites More sharing options...
