BobBrumby Posted October 12, 2004 Share Posted October 12, 2004 I finished off doing my first c.v. today, finishing cause noone was home a 5:30 yesterday to pull on the hub when i was feeding the axle into the car . Instead of taking the outer d.o.j. cup off the tranny I dismantled the d.o.j. while still on the car then withdrew the axle from the car, a bit greasy but saved me buying a new pin and knocking the old one out. I changed out the c.v. and the doj with a used ntn one i had lying around. The doj that i took out of the car would jam and wouldnot move freely but the bearings are held in the cage allot tighter the the one i put back in. As i discovered as they sometimes fell out as i was puttin it in. How do you tell a worn doj? But the good thing now is theres no clacking on right hand turns even at lock . Link to comment Share on other sites More sharing options...
busdriver Posted October 12, 2004 Share Posted October 12, 2004 I finished off doing my first c.v. today, finishing cause noone was home a 5:30 yesterday to pull on the hub when i was feeding the axle into the car . Instead of taking the outer d.o.j. cup off the tranny I dismantled the d.o.j. while still on the car then withdrew the axle from the car, a bit greasy but saved me buying a new pin and knocking the old one out. I changed out the c.v. and the doj with a used ntn one i had lying around. The doj that i took out of the car would jam and wouldnot move freely but the bearings are held in the cage allot tighter the the one i put back in. As i discovered as they sometimes fell out as i was puttin it in. How do you tell a worn doj? But the good thing now is theres no clacking on right hand turns even at lock . I'm getting ready to switch out my cv, what is a d.o.j. cup? All of the cv I have ever done just pull out of the tranny and are retained by a circlip inside the tranny. Is this like yours? Link to comment Share on other sites More sharing options...
mcbrat Posted October 12, 2004 Share Posted October 12, 2004 the front axles have a DOJ (Dual offset Joint) on the inner tranny side, and a CV on outer side Link to comment Share on other sites More sharing options...
NorthWet Posted October 12, 2004 Share Posted October 12, 2004 ... All of the cv I have ever done just pull out of the tranny and are retained by a circlip inside the tranny. Is this like yours? All of the Subarus that I have done use a roll-pin through the axle's end cup and through the tranny/diff/rear-hub stub axle. (Don't know about Legacy/impreza or pre-EA81.) This roll-pin needs to be driven past the stub axle using a long-nosed (2.5-3 inch long) punch just under 1/4inch dia (7/16ths???). The front outer CVs include the stub-axle which pases through the hub and its bearings, secured by axle nut. Link to comment Share on other sites More sharing options...
torxxx Posted October 12, 2004 Share Posted October 12, 2004 This roll-pin needs to be driven past the stub axle using a long-nosed (2.5-3 inch long) punch just under 1/4inch dia (7/16ths???). QUOTE] 7/32" chainsaw file or pin punch works perfect for the job. the chainsaw file makes it a little easier because its longer then a punch. (lessens the chance of hitting your hand on something while pounding it out. Link to comment Share on other sites More sharing options...
busdriver Posted October 12, 2004 Share Posted October 12, 2004 This roll-pin needs to be driven past the stub axle using a long-nosed (2.5-3 inch long) punch just under 1/4inch dia (7/16ths???). QUOTE] 7/32" chainsaw file or pin punch works perfect for the job. the chainsaw file makes it a little easier because its longer then a punch. (lessens the chance of hitting your hand on something while pounding it out. Is this roll pin something I'm going to be able to see on the axle, or trans? I'm worried once I get this apart I won't be able to find it, I've never done a subaru before. Link to comment Share on other sites More sharing options...
stngllhm Posted October 12, 2004 Share Posted October 12, 2004 it is on the half shaft it is easy to see. personlly i think soobs are easier than most other cars Link to comment Share on other sites More sharing options...
NorthWet Posted October 12, 2004 Share Posted October 12, 2004 ... punch just under 1/4inch dia (7/16ths???)... Math is HARD!!! I meant 7/32nds. Thanks Torxxx!!! Link to comment Share on other sites More sharing options...
bushbasher Posted October 13, 2004 Share Posted October 13, 2004 3/16 punch fits perfect. Link to comment Share on other sites More sharing options...
