stngllhm Posted October 12, 2004 Share Posted October 12, 2004 i've got a dual range tranny and 3.9 diff i would like to put in my 87 gl-10 wagon is there any differance in how strong the d/r is in ralation to the 5 speed on-demand i have in there now. so in short if i do the swap is the d/r going to hold up i was told that the turbo tranny is built more heavy-duty that is why i am asking Link to comment Share on other sites More sharing options...
calebz Posted October 12, 2004 Share Posted October 12, 2004 It will bolt right in.It will hold up. I haven't seen anything that suggests to me that the turbo pushbutton tranny is stronger than the N/A PB tranny they used , or the the D/R tranny. Just be sure to put the matching rear diff in. Link to comment Share on other sites More sharing options...
NorthWet Posted October 12, 2004 Share Posted October 12, 2004 It will bolt right in. Any axle/spline/size issues that need to be considered? I know there are differences MT vs AT, how about turbo vs non-turbo? Link to comment Share on other sites More sharing options...
WJM Posted October 12, 2004 Share Posted October 12, 2004 actually you will need the NA axles that come with the NA trans...front ones only tho. The rears are the same regardless. 23 spline count for the NA and all autos, and 25 for Turbo 5MT FT4WD, 4WD, and XT Turbo 2WD and 4WD and FT4WD Link to comment Share on other sites More sharing options...
calebz Posted October 12, 2004 Share Posted October 12, 2004 Doh! forgot to mention the axles.. thanks will Link to comment Share on other sites More sharing options...
stngllhm Posted October 12, 2004 Author Share Posted October 12, 2004 well that sucks the cvs with the d/r are bad and the one on my turbo are good. what about the hubs Link to comment Share on other sites More sharing options...
WJM Posted October 12, 2004 Share Posted October 12, 2004 well that sucks the cvs with the d/r are bad and the one on my turbo are good. what about the hubs Hubs are the same...85-94...DL, GL, GL-10, RX, XT, Leone, Loyale...NOT XT6 tho. so are the CVs completely destroyed? I wouldnt think so...take them apart...clean them...repacc with subie grease....put subie CV boots on them, and clamps...and install away! Link to comment Share on other sites More sharing options...
stngllhm Posted October 12, 2004 Author Share Posted October 12, 2004 the splines on the hub end are thrashed pretty bad. Link to comment Share on other sites More sharing options...
WJM Posted October 12, 2004 Share Posted October 12, 2004 oh... well...see if the outer CVs from the turbo ones will fit the shafts on the NA ones...ive never tried that....but it might work.... Link to comment Share on other sites More sharing options...
stngllhm Posted October 12, 2004 Author Share Posted October 12, 2004 isn't the inner joint easier to get apart Link to comment Share on other sites More sharing options...
WJM Posted October 12, 2004 Share Posted October 12, 2004 depends...could try that too... 2 things to get the DOJ off...a big circlip deal in a gap on hte DOJ cup...and then an internal snap ring on the end of the shaft holding the DOJ balls and cages on. The CV...secure the sahft...and gently beat the CV assy off the shaft...pops out. Link to comment Share on other sites More sharing options...
MilesFox Posted October 12, 2004 Share Posted October 12, 2004 oh... well...see if the outer CVs from the turbo ones will fit the shafts on the NA ones...ive never tried that....but it might work.... the doj from a 3at turbo axle is the same diameter as the 25 spline axle, but it has a 23 spline count. this way you can have a 23 spline axle that has the turbo durability. if you decide to but new axles altogether order for a turbo automatic 3spd, any model, as long as its not for full time autos(4spd) Link to comment Share on other sites More sharing options...
PoorManzImpreza Posted October 12, 2004 Share Posted October 12, 2004 are the full-time 4eat turbo trannies 23 or 25? Link to comment Share on other sites More sharing options...
calebz Posted October 13, 2004 Share Posted October 13, 2004 25 Link to comment Share on other sites More sharing options...
BobBrumby Posted October 13, 2004 Share Posted October 13, 2004 are the turbo\NA doj the same size ? Cause if thats true could u just use NA doj outer cup with the turbo axles\doj midle-race and bearings. Do turbo backends e.g. lsd's have the same spline count as NA rear diffs? Link to comment Share on other sites More sharing options...
WJM Posted October 13, 2004 Share Posted October 13, 2004 are the turbo\NA doj the same size ? Cause if thats true could u just use NA doj outer cup with the turbo axles\doj midle-race and bearings. Do turbo backends e.g. lsd's have the same spline count as NA rear diffs? rear diffs are the same. Link to comment Share on other sites More sharing options...
MilesFox Posted October 14, 2004 Share Posted October 14, 2004 are the turbo\NA doj the same size ? Cause if thats true could u just use NA doj outer cup with the turbo axles\doj midle-race and bearings. Do turbo backends e.g. lsd's have the same spline count as NA rear diffs? the 23 spline from 3at, the 25 spline from full time 4at and turbo 5spds are the same, as well as xt6. all you have to do is swap the proper cup end onto the axle you are using, and install a new boot clamp Link to comment Share on other sites More sharing options...
