s'ko Posted October 14, 2004 Share Posted October 14, 2004 So I got me a third light that I will be installing. Now I need to know how to get the cover to open. I figured out how to get the light to turn on. I just can seem to get the motor to work. anyone w/a working third light out there that can give me a hand? BW Link to comment Share on other sites More sharing options...
ezapar Posted October 14, 2004 Share Posted October 14, 2004 http://www.ultimatesubaru.org/forum/showthread.php?t=16945&highlight=cyclops+wiring McBrat has a diagram somewhere too. Link to comment Share on other sites More sharing options...
mcbrat Posted October 14, 2004 Share Posted October 14, 2004 if you go to Radio Shack (or equivalent electronics supply type store) you can get a DPDT Switch and wire it using this diagram.... http://www.ultimatesubaru.org/80s/diagrams/centerlamp-wire.jpg I have a writeup somewhere that uses a stock switch and a DPDT Relay that CLantieri wrote up a while back.... but not sure where it's at.... Link to comment Share on other sites More sharing options...
bheinen74 Posted May 21, 2009 Share Posted May 21, 2009 i wish the old links worked. I am looking for wiring info on the cyclops. Link to comment Share on other sites More sharing options...
TomRhere Posted May 22, 2009 Share Posted May 22, 2009 PM sent Link to comment Share on other sites More sharing options...
mcbrat Posted May 22, 2009 Share Posted May 22, 2009 i wish the old links worked. I am looking for wiring info on the cyclops. should be under the subaru's of the 80s site now..... Link to comment Share on other sites More sharing options...
bheinen74 Posted May 22, 2009 Share Posted May 22, 2009 pretty sure i found the factory relay. I will post up pictures tonight. the only part of the wiring i still need to pull is from the small connector out the relay from under the engine compartment, going to the cab to the center lamp switch. Everything else ii have pulled out. Link to comment Share on other sites More sharing options...
