archemitis Posted October 21, 2004 Share Posted October 21, 2004 then you sir, need a new clutch, or something is funny. you can bend your clutch bedal arm, and get it where you want it, but to adjust it, you dont even look at the clutch pedal, just the arm, and double nuts, at the cable. under the spare tire. Quote Link to comment Share on other sites More sharing options...
archemitis Posted October 21, 2004 Share Posted October 21, 2004 now im confused, you payed 150 bucks, and now your adjusting it yourself... go make them finish the job right! Quote Link to comment Share on other sites More sharing options...
Alexx Posted October 21, 2004 Author Share Posted October 21, 2004 It's not that far off. I'm just trying to understand how much room to the floor is ideal when pressing in the clutch. Quote Link to comment Share on other sites More sharing options...
archemitis Posted October 21, 2004 Share Posted October 21, 2004 yar, thats why i say adjust the cable how itshould be, with the free play, then bend your pedal to sit where you want it =] as far as i know, all my subarus clutch pedals hit the floor when i shift. Quote Link to comment Share on other sites More sharing options...
Alexx Posted October 22, 2004 Author Share Posted October 22, 2004 But when you are at a red light you don't want your foot jammed all to the floor waiting for the light to turn green, do you? ------------------------------------------------ I took off the spare tire and noticed something odd. There are two rubber washers that I assume go on each side of the clutch harness/car mount where the cable harness ends and the last part of the actual cable comes through. Both of the rubber washers were on the same side of the mount. Well, one of the rubber washers looked like it was on both sides of the mount. I noticed that as the cable came out of the harness it was at a slight angle. Over time the slight angle can cause additional friction against the cable harness. I loosened the two nuts and was able to correctly reposition the rubber washer, one on each side of the harness mount, and then I set the reset the nut to where I liked it best. It took me two readjustments of the nuts to get the pedal exactly the way I like it. I disagree that bending the pedal is the way to get the ideal setting, I think it takes a bit of tinkering to get the clutch pedal to engage exactly where it feels comfortable. Quote Link to comment Share on other sites More sharing options...
