4RnrRick Posted October 15, 2004 Share Posted October 15, 2004 Just curious if there is a spread sheet or table somewhere that shows the lift/fender modifications required for a certain tire size for the different models of Subies. I know there are lots of tire fitment posts on here but I haven't seen any that shows a general table....... But the real question I have is: if I'm going to get a Subie with the plan of running large tires - Iis there a certain model that is easier to make large tires fit? Hope that makes since. Link to comment Share on other sites More sharing options...
mcbrat Posted October 15, 2004 Share Posted October 15, 2004 the ea82's like the 85-89 wagons you're thinking about have bigger opening that the older wagons. one of the problems with cutting up into the rears of the older 80-84's is that you start getting into 2 layers. the outer skin, and the inner well. then you need to look at sealing that area up again. not sure about the 85-89 style though.... I think to run 27/28's with a 3" lift on a ea82 is no cutting in the back, and very minimal trimmin in the front... at least that's what it looks like on the wagon I just got.... Link to comment Share on other sites More sharing options...
