Interest meter #2...5 lug.
WJM
If expanded wheel choices are what you are after, remachining just the hubs will be fine.
However, I have found there is sooo much potential whan you change the front end over to that of an impreza. Huge aftermarkets exist for performance struts, springs, brakes...
Also with the Impreza front knuckle you gain a better bearing system, so they are less likely to wear out like on the EA82.
I would look at making custom lower control arms for the front that match the XT6 ones. Also provide in the kit a new rear hub and backing plate (or caliper spacer). As these are really the hard to find parts. The parts that *need* to be XT6.
