rich fuel mix
my 88 gl fuel injected sube has a problem with its fuel mix i just changed my plug wires and checked my distributer. the exaust smells like gas, so i think that the fuel mix is too rich. i also noticed a loss in power and some missinging in the 3k to 4k rpm range. it may be the fuel pressure regualtor? i dont know if anyone can give me some advice please post it
thanks
thanks
Could be that the disty is too far retarded...advance it some/check the timing and make sure the timing is correct. Should be around 20 deg BTDC.
The ECU watches the mix via the 02 sensor.
It then changes the injector pulse width duration to
adjust the A/F ratio.
Operative unit -->the 02 sensor.
Subaru engineers have been forward thinking enough
to provide you with a relatively simple way to monitor this.
Remove the panel under the steering col.
warm the engine to op temp.
Watch the LED on the end of the ECU
(bolted under the st. col.)
(this LED is called the 02 monitor BTW
and is the same one for checking error codes)
At idle the light should flash in random intervals
with a frequency of approx. once every
few seconds.
IF it does not flash the 02 sensor is tired
and wants replaced.
NOTE: contrary to what people will tell you
a lazy 02 sensor will NOT set an error code in the ECU.
You may be running rich and have fouled spark plugs
put a set of fresh NGK's in if you can afford it.
Hope this helps
