SUBARU3 Posted October 19, 2004 Share Posted October 19, 2004 Quick question: Will all EA-71 cylinder heads, (regardless of year), interchange with all EA-71 blocks, (regardless of year)? Are the pushrods the same? Disregard the emission stuff, EGR , air suction ect, I can make that all work. But am I missing something? Can a 1984 EA71 take the cylinder head from a 79 1600? They physically look the same. Todd Link to comment Share on other sites More sharing options...
the sucker king Posted October 19, 2004 Share Posted October 19, 2004 i took apart e pre '80 ea71 and the valve rockers wer held on by long bolts. on a post 80 they were slipped over studs and were held on with nuts. subtle but different. i've also been told that a hydro lifter ea71 will have pushrods with different tips. Link to comment Share on other sites More sharing options...
GLCraig Posted October 19, 2004 Share Posted October 19, 2004 The heads can be interchange but try to use 79? or later heads since they came with better valve spring retainers. Pushrod interchange depend on the lifters, you don't want to mix and match solid lifter pushrods with hydraulic lifter pushrods and vice verca. Link to comment Share on other sites More sharing options...
SUBARU3 Posted October 19, 2004 Author Share Posted October 19, 2004 Did EA71's even come with hydralic lifters? Todd Link to comment Share on other sites More sharing options...
the sucker king Posted October 19, 2004 Share Posted October 19, 2004 the late ones did. Link to comment Share on other sites More sharing options...
CIS Subaru Posted October 20, 2004 Share Posted October 20, 2004 the late ones did. Not in the U.S. Our EA71s were all solid lifter. The '84 and later EA71s did have different heads though, but only in that they had the larger EA81 valves in them. Link to comment Share on other sites More sharing options...
mcbrat Posted October 20, 2004 Share Posted October 20, 2004 Richierich had an issue a long time ago with a Gen1 Brat. Turned out he had an older solid lifter block with the newer style heads.... I believe he had to change them to the old style heads... Richie, you out there? Link to comment Share on other sites More sharing options...
SUBARU3 Posted October 20, 2004 Author Share Posted October 20, 2004 So the old heads, 78,79 can go on a later, 81-84 EA71 block? (Absent the EGR, air suction modification that will need to be done.) Todd Link to comment Share on other sites More sharing options...
mcbrat Posted October 20, 2004 Share Posted October 20, 2004 Todd, I'm hoping Richie shows up, as I don't know the specifics.... there are a few JDM EA71's around with hydraulic lifters.... Link to comment Share on other sites More sharing options...
SUBARU3 Posted October 20, 2004 Author Share Posted October 20, 2004 I have determined that these are solid lifters. Todd Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted July 3, 2014 Share Posted July 3, 2014 ...there are a few JDM EA71's around with hydraulic lifters.... ~► http://www.ultimatesubaru.org/forum/topic/138256-ea71-with-hlas-and-points/?p=1163588 Link to comment Share on other sites More sharing options...
