78 brat vs 82 brat NEED QUICK RESPONCE
the 78 im looking at has been transfored to the 1800cc dual range 4wd and the 82 has a webber carb. i think i like the style of the 78 but is their any differnce in wheel dimensions/ground clearance is one just a better vehicle? i want good off road capabilities, is the 2nd gen easier to upgrade?
I believe the 82 is a better vehicle to lift.
The reason I like the 82-87 is that the bed is 4 foot wide and I can fit a piece of plywood in the back. Not really a big deal if you have a full size truck, but if this is going to be your only "truck" then it something to consider.
the second gen has a readily available lift from http://www.ozified.com , but you can get a lift for the gen1 from mudrat79 in Eugene.
parts are probably a bit easier to find for the gen2, but since the 78 has already been converted to 1800 and D/R. it will come down to other less important things:
tilt steering wheel
roominess in cab
bed capacity
body style you prefer
I like the style of the Gen1 too, but prefer the bigger size of the Gen2...
