pwoens Posted October 23, 2004 Share Posted October 23, 2004 Can I put a DR 5spd all wheel drive tranny, ect..from an 89 RX, in my 88 turbo wagon?? Im assuming if it works I would have to transfer axles, diffs, ect... Curious if the driveline is a different length or of any issues that might not make this a feasible swap?? Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 23, 2004 Share Posted October 23, 2004 you sure can -Brian Link to comment Share on other sites More sharing options...
calebz Posted October 24, 2004 Share Posted October 24, 2004 You don't say what you have in your turbowagon currently. If your car is already a factory turbo 5 speed, then the major componants you already have.. axles, diff, etc will work fine Link to comment Share on other sites More sharing options...
AEIOU Posted October 24, 2004 Share Posted October 24, 2004 Isn't that exaclty what subaru styles did? He basically turned his wagon into an RX Wagon. Link to comment Share on other sites More sharing options...
calebz Posted October 24, 2004 Share Posted October 24, 2004 Actually, IIRC, brad has the single range FT4WD trans in the RX wagon.. As do I. Link to comment Share on other sites More sharing options...
subaru_styles Posted October 24, 2004 Share Posted October 24, 2004 yeah i opted to use an xt6 fulltime tranny as it is the only FT w/diff lock that is a 3.90 Link to comment Share on other sites More sharing options...
