camosuba Posted October 27, 2004 Share Posted October 27, 2004 So how long did he leave his truck running for ? that sounds like a good thread longest nonstop running of a subaru engine? P.s. our coldest day here in winter was hmm 5 degress C Quote Link to comment Share on other sites More sharing options...
Snowman Posted October 27, 2004 Author Share Posted October 27, 2004 I dunno about a soob engine, but GM recently released a hi-po engine and to test it, they put it on the dyno, ran it up to max power, and let it sit there for four days. Quote Link to comment Share on other sites More sharing options...
Setright Posted October 27, 2004 Share Posted October 27, 2004 Three 200bhp two-liter Turbo Legacies did 100,000km stopping only for fuel/oil service at the launch in 1989. Beat numerous records on the way. Quote Link to comment Share on other sites More sharing options...
snowstormer Posted October 27, 2004 Share Posted October 27, 2004 we had a winter up here-1996-97 i think. many nights of -35. plugged in soob worked fine. one night got to around -50. coldest i have ever seen it. still dont believe my two thermometers. otheres locally had it also... but the point being- my soob started up reluctantly. plugged in with block heater. made some weird noises, let it run in neutral 10 minutes or so. put it into gear, pressed on gas, it would not move, pressed gas, finally almost to floor[auto tranny] car started to creep forward. problem was- the back wheels would not turn on the hard packed snow, they just slid. wheel bearing grease must have been too stiff. or rear diff- had 80w 90 in it. non-syn. after about a half mile or so, they started to turn. dont know how this pertains to you, just thought i would throw it out there. car was an 86 gl- carb. i was impressed that it still ran. many newer cars were dead along the hwy. Quote Link to comment Share on other sites More sharing options...
Snowman Posted October 27, 2004 Author Share Posted October 27, 2004 Setright: I had heard that the legacy has the 100,000k speed record, but nothing beyond that. Where might I find more about this because I think that's the coolest thing ever. Snowstormer: WOW! Subes are usaully great about dealing with low temps, but I am truly impressed! Quote Link to comment Share on other sites More sharing options...
Steves72 Posted October 28, 2004 Share Posted October 28, 2004 dual optima yellowtops would be elite!!! cause they are drycell (some consider them gel cells) instead of lead acid batts which means NO WATER and might even think of running ATF in the tranny even though I dunno how the center diff would take it unless are they sealed? but yeah think of the ATF thing cause I used to have a camry that had that for the manual tranny and a manual tranny would be better for reliability and oh yeah if a open diff in the back is used try the ATF thing on that too cause it is somewhat light but lubricates well Sorry to burst the bubble, but Optimas are not dry cell batteries. They have a fiberglass weave mesh between the plates. Water is absorbed into the mesh leaving nothing to spill. But, they will freeze. So do not discard the battery heater. Steve Quote Link to comment Share on other sites More sharing options...
