monstaru Posted October 25, 2004 Share Posted October 25, 2004 just got the new tranny in and after a look at the engine during the work i realized that being full of oil the whole time it was not leaking....hooked up the starter and everything else and started her up...wow does she run strong.even without the y-pipe hooked up.heheheh she sounds like an airplane:brow: the y-pipe to go on is from an ea82 for some extra flow.the lift should be here in a month or so.she is coming along.i was the ***hole of the neighborhood as she was running .wow is that loud!i must say that moving the engine forward is the only way to go when it comes to messing with your tranny yourself......yeeeehaaaawwww!!!!!!!!!!!!!!!!!!!!111 Link to comment Share on other sites More sharing options...
dustyrider Posted October 25, 2004 Share Posted October 25, 2004 the y-pipe to go on is from an ea82 for some extra flow. will you need to do any fabrication for this to work? i have access to ea82 exhaust stuff just wondering! Link to comment Share on other sites More sharing options...
Flow Posted October 25, 2004 Share Posted October 25, 2004 Good to hear your up and running. So did you stuff that solid lifter motor in or are you still running the hydro? How's the tranny shift? Dusty Link to comment Share on other sites More sharing options...
monstaru Posted October 25, 2004 Author Share Posted October 25, 2004 no, it bolts right up.it is advised that you use the better gaskets though.. Link to comment Share on other sites More sharing options...
monstaru Posted October 25, 2004 Author Share Posted October 25, 2004 i had it up on blocks and it shifted fine...up and down....i still have the hydro in her.i am going to keep it in to see how it does.either way one of them is getting "built".probably the solid now that i think of it.she will be on the road this week...at least to test drive.gonna keep her garaged till the lift gets here. Link to comment Share on other sites More sharing options...
