newbie needs to check out 92 legacy
Hello All
I am deep into motorcycles (see nick), done from the ground up restorations, so quite technical.
Yet, I want to buy a 92 legacy GL SW with 60K miles and do not know much about problems points, what to check etc. Any help/tips will be appreciated.
I am in Italy, hence motor is 2.0.
Any links for model history, tech info?
Cheers
turboguzzi
PS If anybody has any motorcycle mechanics questions, I'll be glad to help
A 92 with 60K on the clock! Buy it! That car has along wat to go. just change the timing belt before 100K. While they are doing that they should do all the cam, crank and oil seals, not to mention the tensioner and idler pulleys. That will ensure your car will have as many miles on it as mine. 236K and still running like a champ.
Hope this helps.
P.S. Thanks for the awesome food. Chao...
Hi short lid.
Yes, shoot. I run a 89' GSXR1100 (that makes more power than the legacy I intend to buy :)) + a host of others. Restored my share of british classics too. Actually I need this legacy to tow my bike trailer...
OLS. its 105K kilometers = about 60K miles. I converted for you "americani" :)
I am spoilt for choice: one is 1250$ (1000 euros) but a bit scruffy body wise, another at 2500$ but unbelivable well kept, one lady owner, not a scratch. both have 60K Miles and are manual. Then there is another but automatic at 2000$, 65K.
Still no info on any proper tech site or buyers guide? Got very little from searching google.
Cheers
T-G
Wheel bearings
half shafts
fuel sending unit
transmission components for torque bind and bleed down if auto
(make sure fuse is not in awd holder)
Driver side visor
Make sure the check engine and ABS (if equipped) lights come on at start-up
First generation Subarus are worth buying. Good luck.
