beezer Posted October 29, 2004 Share Posted October 29, 2004 Hi first time posting, just like to say "hi" to everyone. I recently bought a 92 Legacy and I need some advice on replacing the front rotors and the front driverside axle. Never worked on a Subaru so no detail is to small. Thanks hopefully someone can help me. PS already love my Subaru! Link to comment Share on other sites More sharing options...
northguy Posted October 29, 2004 Share Posted October 29, 2004 Your best bet is to: 1. Visit the USRM on this site and then 2. Go buy a reliable manual to walk you through the process. Neither operation is too technically difficult, but to give detailed information is time-consumptive and probably redundant - visit the USRM first. It has a ton of good info. Good luck. Link to comment Share on other sites More sharing options...
Gnuman Posted October 29, 2004 Share Posted October 29, 2004 If you work on your own Subaru, you will find a lot to love about that car. My BIL said that when he pulled the front wheels on his Brat, he had all kinds of problems, but I had none at all on my 92 Legacy Wagon (AWD). I went out and bought a Haynes manual for it ( I do this for every vehicle I plan on working on regularly) and the manual you need is number 89100 which covers all 1990 to 1998 Subaru Legacy models. OK, I lied a bit. Finding a puller to push out the ball joints from the lower control arm was a pain, and I ended up using a picke fork to seperate that connection (It came off real easy that way). this was not a real problem for me, as I was replacing the ball joints at the same time as the clutch (which was the reason I was pulling the drive axels in the first place) so the damage to the ball joint boot was irrevelant. My preference is to use a puller to avoid such damage. The ones I was able to find would not fit. . . Link to comment Share on other sites More sharing options...
beezer Posted October 29, 2004 Author Share Posted October 29, 2004 thanks for your advice, I will go looking. thanks again northguy said: Your best bet is to:1. Visit the USRM on this site and then 2. Go buy a reliable manual to walk you through the process. Neither operation is too technically difficult, but to give detailed information is time-consumptive and probably redundant - visit the USRM first. It has a ton of good info. Good luck. Link to comment Share on other sites More sharing options...
beezer Posted October 29, 2004 Author Share Posted October 29, 2004 I will try and find a manual and then all I will need is a little luck and maybe a beer. thanks for your time I appreciate it. Beezer Gnuman said: If you work on your own Subaru, you will find a lot to love about that car. My BIL said that when he pulled the front wheels on his Brat, he had all kinds of problems, but I had none at all on my 92 Legacy Wagon (AWD). I went out and bought a Haynes manual for it ( I do this for every vehicle I plan on working on regularly) and the manual you need is number 89100 which covers all 1990 to 1998 Subaru Legacy models. OK, I lied a bit. Finding a puller to push out the ball joints from the lower control arm was a pain, and I ended up using a picke fork to seperate that connection (It came off real easy that way). this was not a real problem for me, as I was replacing the ball joints at the same time as the clutch (which was the reason I was pulling the drive axels in the first place) so the damage to the ball joint boot was irrevelant. My preference is to use a puller to avoid such damage. The ones I was able to find would not fit. . . Link to comment Share on other sites More sharing options...
