hitachi probs.
OK people, I need a silver bullet here. My 84 5-speed rustbucket (2wd) has decided it doesn't like full throttle anymore. 1st and 2nd are OK, but go WOT in 3rd or higher and it quits just after hitting 3000 RPM. The pause is momentary - about 3-5 seconds, then it lights up again but only for another 5-10 secs. before beginning the routine all over again. Momentary fuel starvation is my guess, I'm hoping one of you can say "Aha!!" and share your experience before I start digging. (The Hitachi has been rebuilt by me - successfully - last year so it's clean and tight) All comments gratefully accepted.
The filter that is normally the culprit is the one
back by the fuel pump under the car.
This the main or "primary"
filter. It is the one that seldom gets changed
and is first in the line of defense against
dirt and therefore takes the biggest hit.
BTW
The one under the hood is called a
"Vapor Separator"
Hope this helps, most of us "carb types"
have BTDT
on this problem
BTW
"Vapor Separator"
have BTDT
on this problem
Thanks folks. I ordered filters today and I was advised there are 2 filters, primary and secondary. Am I to assume the secondary refers to the "vapor separator" or should I follow the old rule that says "NEVER ASSUME!"? A word of advice would be welcome while I wait till the truck gets to Oliver on Monday with my parts. Cheers!!
Thanks everyone. Both filters installed and problem solved. One look at the rear filter full of rust-colored sediment told the tale. I previously had to change a rusted-out and leaking filler pipe but of course ignored the filter that was hiding behind the splash shield. USMB does it again!! (For the record the Fram part ##s are G4167 and G4917 - about 6 bucks ea. Canadian)
Paul
