torxxx Posted October 30, 2004 Share Posted October 30, 2004 Anyone ever have a engine run with no fuel pump? I just happened to test my pump last night, and it doesnt work. I think my car has been like that since I got it 6 years ago. Its never cold started right, and after it sat for more then 4 or 5 days, you'd have to pump the gas pedal til your foot hurt to get it started. I've always thought a car needed a pump to move the fuel since the tank is in the back and lower then the engine, but apparently not. Link to comment Share on other sites More sharing options...
snowstormer Posted October 30, 2004 Share Posted October 30, 2004 you guys must have some good hooch up there! Link to comment Share on other sites More sharing options...
torxxx Posted October 30, 2004 Author Share Posted October 30, 2004 LMAO.... Its just another one of those unexplainable subaru phenomenons Anyone else ever have this happen to them? Link to comment Share on other sites More sharing options...
northguy Posted October 30, 2004 Share Posted October 30, 2004 Happy to see you figured out the problem. Have you put a new one on yet? How is Haggard running now? Link to comment Share on other sites More sharing options...
Bkillazrallying Posted October 30, 2004 Share Posted October 30, 2004 thats cool, i wish when my fuel pump died my legacy had kept running... but no, it definitely died on me... a strange phenomenon indeed... wish i had had that luck haha Link to comment Share on other sites More sharing options...
archemitis Posted October 30, 2004 Share Posted October 30, 2004 it cant get fuel from below the carb up to the carb witout some kind of pump. you must have tested it wrong. gravity doesnt work like that. Link to comment Share on other sites More sharing options...
WoodsWagon Posted October 30, 2004 Share Posted October 30, 2004 If the bowl vent was plogged, maybe the suction from the jet would pull gas from the tank, but it seems very unlikely to me. The pumping of the accelerator may have been pulling gas from the tank through the suction of the accelerator pump, but I doubt the car would run without the pump. Link to comment Share on other sites More sharing options...
jeffroid Posted October 30, 2004 Share Posted October 30, 2004 How did you test it? I had a similar thought when I went to test mine by taking if off the car and hooking up my battery charger to it. My charger has a switch with three different settings on it. I believe the settings are 3 amps (trickle charge), 10 amps (fast charge), and 50 amps (start). The pump would only work with the charger set on the start mode. The fuel pump circuit is protected by a 15 amp fuse, so that makes sense, I guess. Link to comment Share on other sites More sharing options...
torxxx Posted October 30, 2004 Author Share Posted October 30, 2004 archemitis said: it cant get fuel from below the carb up to the carb witout some kind of pump. you must have tested it wrong. gravity doesnt work like that. Its all about suction. Every time I take my gas cap off the tank is pressurized. On the engines in our boats, some guys run with out a fuel pump. once you get that fuel line full of fuel, it will suck its own fuel (to a certain point) my car bogged down hard at higher RPMS. To test it I pulled the fuel line off, started the car and watched for fuel to come out of the fuel line. Nothing came out at all with the old pump on. Installed the new one, fuel sprayed everywhere. Most noticable on the upper RPMS. Link to comment Share on other sites More sharing options...
archemitis Posted October 30, 2004 Share Posted October 30, 2004 i dont believe it one bit Link to comment Share on other sites More sharing options...
torxxx Posted October 30, 2004 Author Share Posted October 30, 2004 dont believe it then. I dont need to argue my point with you Link to comment Share on other sites More sharing options...
edrach Posted October 30, 2004 Share Posted October 30, 2004 Also the level of fuel in the gas tank is likely higher than the delivery point in the engine. I bet you might have had some scary moments when the fuel tank was below 1/8th full and going up a steep hill. Link to comment Share on other sites More sharing options...
