4RnrRick Posted November 17, 2004 Author Share Posted November 17, 2004 Rallywagon said: Looks like an awesome project! Quote Thanks Quote 1. Does the Castrol Super Clean cut the tar like junk used under the carpets? I don't know? never tried since its under the carpet. on my Toyota I can usually peel or chip that crap away. also a wire wheel might get it off Quote 2. What type of welding are you doing on your auto sheet metal projects, and can you give any hints...TIG, MIG, pulsing? I haven't welded on a Subie YET, But on my Toyotas I've done way too much of it. I just a 110 MIG with 75/25 Argon/CO2 Mix with .023 mild steel wire. With my Linclon its on B-3 works pretty good. Teh settings are from A-D and 0-10 if that helps. Then you just do a bunch of spot weld over lapping each other. and don't stay in one place for too long. Say 1" at a time and then skip 4" down the panel. The keey is going nice and slow. Quote 3. What kind of welding rod seems to work well with Japanese auto sheet metal (Subaru if you have gotten that far) in your experience? See above.... Link to comment Share on other sites More sharing options...
Rallywagon Posted November 17, 2004 Share Posted November 17, 2004 Thanks for the comments! Link to comment Share on other sites More sharing options...
