vw_speedsterke Posted November 4, 2004 Share Posted November 4, 2004 i have a ej20 turbo 4cams from '93. can i change the heads with the ej25 4cams head fiom 98? What is the result? Link to comment Share on other sites More sharing options...
Legacy777 Posted November 5, 2004 Share Posted November 5, 2004 They'll bolt on....however I can't tell you whether the intake manifold will have some issues aligning properly, or if the coolant passages and other stuff will be exactly the same. Also....the turbo heads will have a line for oil to feed the turbo...the n/a heads won't. I'd probably pass on swapping. Why are you looking to do this? Link to comment Share on other sites More sharing options...
