  coloradosubarules said:
I hear if you leave the plug out for a few hours you will get most of it out. I noticed on my car (auto) that it just kept draining real slow after the majority was out.
This is not true, you will never get all the fluid out of the system without flushing it with a mahcine. You can flush it yourslef by pulling a hose off and using a bucket but it is messy job.
  99obw said:
I just did this a couple of nights ago and I got about 5.5 quarts out on ramps. I just changed the filter and refilled it, I need to go back and flush it when I get a chance. Flushing isn't messy if you are careful.
So how did you flush it?
The only way I know to flush with out a machine is this method.
1. Pull off one of the transmission return lines from the radiator and put the end into a bucket.
2. Start the car and run it until you get 2 quarts in the bucket
3. Turn off car
4. Refill 2 quarts into the transmission
5. Repeat step #2, #3, #4 until you get clean fluid going into the bucket.
This is the only way to get all the fluid out of the torque converter.
When you pull the plug and filter you only get about 5 or 6 of the 8 quarts in the system.
  99obw said:
Yep, that's how I do it. Not messy if you are careful. Pulling the pan seems to be most of the mess associated with tranny service, and since the filter is external I have never pulled the pan on our outback.
I have never had a auto subaru before.
External filter is nice!!
I have been know to at times kick the bucket over!! Making large a mess!
